RANDOM operator
  • Mar 24, 2023 11:47 AM UTC
  • 123 views
Hello, In the analysis view, I would like to multiply a set of values with a random operator similar to RAND() in excel however I cannot find anything like this in the documentation.
Does anyone know if there is such an operator ?
Thank you
  • Mar 24, 2023 11:57 AM UTC
Hey Rodrigo,
Indeed in the PQL library there is no RANDOM functionality. I'm not sure what your use case is for this, but you could look into the RANDOM() and RANDOMINT() functionalities of vertica which are supported (Supported Vertica functions (celonis.com)). You can add a column or table to your data model for example through the data transformations as a workaround.
  • Mar 24, 2023 12:03 PM UTC
Hello, thank you for the quick answer!
How can I use these vertica functionalities in my analysis?
  • Mar 24, 2023 1:38 PM UTC
Not directly in an Analysis, but you can access vertica functions in data integration, through data jobs.
