Hi expert,
I'm not quite good at SQL and I have a question about SQL. In my case, I would like to filter activity table with event time with its only time(hh:mm:ss). Does anybody let me know how to do that in Celonis data integration task?
Hi expert,
Best answer by Anonymous
Thanks for your quick responce and my case is latter one, I created activity table but there is some of 00:00:00 as event time(date time format.). So I would like to find out those no-time activity and update those time to correct order in process explorer.
Two ways:
HTH
BTW is one of my standard test. Of course I do it over the extracted tables. I do check no time part, if there are dates in the future, and, of course, nulls and empty values.
