Pushing Data to a Specific Data Connection using Data Push API
  • Aug 23, 2022 8:23 AM UTC
  • 123 views
Hello Peers,
I am now testing Data Push API by following the instruction of this course in Academy. Data Push API Basics - Data Push API Basics | Partner (celonis.com)
Though I have updated my connection ID in body of "Create Push Job", the response after submitting the data job was like below and connection ID was null. Hence the data was pushed to Global Schema in my environment instead of the specified schema.
imageimage5I am attaching relevant information as follows. I would appreciate for your advice to push the data to the specified schema. I have been using Postman to test the functionality.
POST URL and Body of Create Push Job:
image2POST URL of Push Chunk:
image3POST URL of Submit Data Job:
image4I have double checked my connection ID was updated as variables correctly.
Regards,
Hayamu Takahashi
Dear Hayamu, Please be informed that we created a new Support Case for you as we need to clarify more detailed information. Check your inbox later if you receive an email from us. Best regards, Keiko Koyama | Customer Support
