Process simulation
  • Apr 18, 2022 7:06 AM UTC
  • 54 views
Forum|alt.badge.img+14
Does anyone use the function of simulation?
・What process did you analyze?
・What results have you seen?
・For which KPIs were you effective?
I would like to know what the benefits of using the simulation feature are and if it is actually useful.​
Hi Eri,
Hope you're doing well.
Did you have the chance to look at the documentation regarding Process Simulation ?
https://help.celonis.cloud/help/display/CIBC/Process+Simulation
Hope this cover your questions,
Regards,
Mentor
  • Level 6
  • May 17, 2022 1:24 AM UTC
Thank you for sharing the URL
