Process Explorer seems to be taking forever...pink dots.
  • Sep 2, 2021 2:48 PM UTC
  • 62 views
mohit.mehro12
Level 1
Just installed CPM 4.7.1 ( new install) not upgrade from 4.6.x in our Dev/QA box. We imported a transport of one of the analysis from PROD and brought it into the QA.
Everything is working fine- OLAPs, Charts etc..., except Process Explorer and Variant Explorer seems to be taking forever...pink dots.  Do we need to configure some settings.
Mohit
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Sep 13, 2021 12:52 PM UTC
you could take a look into the memory assigned to the Celonis Java executable, for us memory is usually the issue. CPU less so.
mohit.mehro12
Level 1
hi thanks, the problem was pertaining to a broken graphviz path. It was solved once we updated the graphviz path.
