Process AI, Process Overview, Social PI etc. analysis in Multilog Enviroment
  • Aug 29, 2023 3:19 PM UTC
  • 143 views
Hi all,
i have implemented a multilog and i want to build the following analysis in a multilog enviroment (Eventlog merged is activated in the data model and there are 2 different eventlogs).
The problem i am encountring is that i can't "select" the eventlog to analyse. Everytime i click on any of the following predefined analysis, it automatically choses the _cel_merged_activities (only in Comformance i found the option to change the Eventlog).
imageIs there a workaround or a feature request in Pipeline regarding this? Can i just change the whole analyses to point towards an eventlog of my choice?
Thanks
Himanshu
  • Sep 3, 2023 7:02 PM UTC
I think most of them if edited, you can change to a "custom dimension" where you can put the specific activities table you want.
  • Sep 4, 2023 8:34 AM UTC
In Conformance Check, i can select the custom cimension (on the right hand side in options) as shown below.
But in the Process AI for example, i don't see the button to select the custom dimension. And there is no Yaml file code editor, where i could change the settings in the code.
So where can i edit the component @Guillermo Gost?
Thanks
Himanshu
  • Sep 4, 2023 8:50 AM UTC
Thanks
Himanshu
You are right, you can set up the activity only in Process Explorer (tab and component), Varian Explorer component, and Conformance check tab
Case explorer - no way to change it
Process AI - no way to change that
Process Overview - no way to change that
  • Sep 4, 2023 9:11 AM UTC
Thanks
Himanshu
Which is sad, because the calculations on all mentioned depends more or less on the activity table.
Thanks for your input though :)
