Process AI in analysis need link for deep understanding
  • Apr 6, 2023 6:02 AM UTC
  • 137 views
Hello Celopeers,
I have built KPI dashboards and doing some analysis on process explorer. Manually going through analysis. Heard Process AI will automatically detects deviations and find root causes.
Need to deep drive. if any one knows the link from learning portal pls suggest.
andré.tafur
Level 8
Forum|alt.badge.img+19
Hi Chakradhar,
In Celonis Academy i didn't find a course about this topic, but in the documentation is some informations about Process AI and the Root Cause Analysis, here are the links:
https://docs.celonis.com/en/process-ai.html
https://docs.celonis.com/en/conformance-checker.html#UUID-c01ab242-ea87-4cf6-2423-2e0b523e98fb_id_ConformanceChecker-Performrootcauseanalysis
Hope it helps.
andré.tafur
Level 8
Hi Chakradhar,
Hope it helps.
Also this link is usefull:
https://docs.celonis.com/en/execution-gap-list.html
  • Apr 10, 2023 6:23 AM UTC
Above is for deviations from the happy path.
I found the dimension analysis (i.e. to find if some group or value is associated with an undesirable outcome) too manual and tedious for my liking.
So I usually use RCI part of PYCelonis, and/or K-MEANS, to get a first "high-level" view of what categories and values can be more promising regarding to find causes.
RCA is still in the pycelonis package, but the documentation is only in version 1.7.2 and previous ones
https://celonis.github.io/pycelonis/1.7.1/tutorials/root_cause_analysis/01_Root_Cause_Analysis_Tutorial/
K-Means - https://docs.celonis.com/en/kmeans.html
HTH
  • May 18, 2023 8:36 AM UTC
Hi Guillermo,
when I try to import the RCA I get
ModuleNotFoundError: No module named 'pycelonis.root_cause_analysis'
My PyCelonis Version is '2.0.0'
You said you are still able to the package with PyCelonis 2.0? How do you get it? Or are you using PyCelonis version 1.X?
Thanks in advance.
