Process Adherence Manager
  • Jul 29, 2025 12:47 PM UTC
  • 296 views
sagar.belur
Level 2
Is it possible to look at the list of Cases in Process Adherence Manager, just like it was in Conformance checker?
Thanks
Hello ​@sagar.belur
If you want to look at specific cases in Process Adherence Manager (PAM), you can create a filter in the Knowledge Model and apply it within PAM. Another option is to select specific variants.
Additionally, PAM provides the conformance rate and highlights deviations from the expected process.
Thank You
joaocarlos.macie
Level 6
Forum|alt.badge.img+3
Hi ​@sagar.belur
You can filter for a specific deviation in PAM, and then save that filter in your Knowledge Model and use it in a View with a Case Explorer for example.
I hope that’s helpful.
Joao
sagar.belur
Level 2
  • Level 2
  • Aug 11, 2025 5:02 AM UTC
Thanks that helps, let me check
