Problem with the schema explorer in the Sandbox?
  • Oct 28, 2022 8:06 AM UTC
  • 98 views
Hi everyone,
is there a problem with the Sandbox at the moment? If I execute my SQL-Script in the data job, I receive an error message due the tables are not loaded in the schema explorer.
Does anyone have the same issue or any advice?
  • Oct 28, 2022 11:12 PM UTC
Which component/cluster is in use? Usually if something is wrong, whole cluster like EU-X is affected. You can also check statuses here: https://status.celonis.com/
example URL: https://XXX.try.celonis.cloud
obraz
Mateusz Dudek
