Problem using Conformance Overview and Allowlist
  • Jun 29, 2023 8:32 PM UTC
  • 138 views
kailash.potha12
Hi Claudio,
I had a similar experience. it will show the 100% cases if you wait for sometime. In my case it took 5 min for 6M cases.
  • Jul 3, 2023 2:32 PM UTC
Hi Kailash,
I fix the problem change the local of filter. When I put the filter in Analyses level:
imageIt's not work correctly. But when I put the same filter in Conformance Checker level, it's work correctly:
imageI think it's a bug. I will report to Celonis.
Thanks
