problem in adding an augmented attribute because I need to refer the same table
  • Apr 20, 2026 1:45 PM UTC
  • 435 views
mohan_kb
Level 5
In my table Nomination, the following columns are there Key, KeyType, SourceKey. I want to add an augmented attribute called SourceKeyType with the following logic : For each record in Nomination, I need to find its SourceKey and find the KeyType Corresponds to that SourceKey. For example :
Key KeyType SourceKey
1 GOM 2
2 TRA NULL
After defining augemented attribute
Key KeyType SourceKey SourceKeyType
1 GOM 2 TRA
2 TRA NULL NULL
How to model the PQL?
Best answer by gil.liu
maybe lookup can work?
https://docs.celonis.com/en/lookup.html
Forum|alt.badge.img+2
  • Level 10
  • Answer
  • Apr 21, 2026 1:49 AM UTC
mohan_kb
Level 5
  • Level 5
  • Apr 21, 2026 6:21 AM UTC
Hey ​@gil.liu , Thanks. That worked.
