On prem client was used for automation. When establishing a new connection with SAP, should I choose SAP extractor or on prem client? If I use on prem client, can I develop all the assets on the studio side? (for example: analysis, view etc.)
  • Mar 26, 2024 7:31 AM UTC
  • 77 views
dennis.pflug
if possible you should choose on prem client as SAP extractor is getting replaced by it.
You can do exactly the same things as you are used to. It is not having any negative effect on assets.
SAP Extractor is not getting updated anymore.
BR
Dennis
