OCPM
  • Sep 22, 2025 10:28 AM UTC
  • 333 views
harini.p26
Level 3
I have 2 different data source and initially i build my objects and events in one data source and next i have expanded it to other data source. When i made changes and published to development the perspectives have failed and this had impacted the views that are built on Production perspectives
Once the issue is solved with perspectives the views are again back to normal is there any link between test perspectives and production perspectives.
  • Celonaut
  • Oct 15, 2025 1:11 PM UTC
Hey there!
When working with the object-centric data model in Celonis, it's essential to understand that test (development) and production perspectives are kept entirely separate. The development environment, identifiable by its test: prefix, is designed exclusively for safely validating schema and PQL changes before they impact live content. Views and analyses built on a production perspective will only be affected by changes published to production; a failure in the development environment will not propagate to the live views. Although there is no automatic link between the two, they use the same underlying customer data, which ensures that any tests conducted in the development environment are realistic. This strict separation mandates a best practice where you always validate changes thoroughly in the test environment to prevent untested modifications from disrupting your stable, live applications in production, especially since some critical Celonis apps only function when connected to a production perspective. Hope it helps!
harini.p26
Level 3
  • Level 3
  • Oct 16, 2025 2:16 PM UTC
Thank you for your reply
