O2C data pool data model data loads fail after successful Full Extraction, Full Transformation and Create data model views.
  • Feb 1, 2022 1:06 AM UTC
  • 5 replies
  • 83 views
We are trying to load the out of the Box OTC model. We have successfully completed - the Full Extraction Job ,
the full Transformation Job,
The Create data model view Job
When we schedule the data load of the data model its failing with the following errors
Data model load failed during table export: Data model tables could not be exported: O2C_VBRP, O2C_MARC, O2C_KNKK, O2C_VBUK, O2C_VBUP, O2C_VBFA, O2C_VBAP, O2C_KNA1, _CEL_O2C_ACTIVITIES, O2C_KNB1
Hello Victor,
Could you kindly provide us with any screenshot and logs? It's also strange because these seems like they should be created by transformations, and not exported. Especially _CEL_O2C_ACTIVITIES - it's table created in Celonis, so why it would have to be extracted form any source?
Best Regads,
Mateusz Dudek
  • Level 2
  • Feb 2, 2022 11:09 PM UTC
Hello Victor,
Best Regads,
Mateusz Dudek
Hello Mateusz, We have uploaded the O2C connector and run the full Extraction , Transformation and Create Data Model Jobs successfully . I don't have logs to share . [cid:image003.png@01D81846.0B7628A0] On the next step we navigate to the Data Model tab [cid:image002.png@01D81846.CFCAEE70] [cid:image005.png@01D81846.CFCAEE70] [cid:image006.png@01D81846.CFCAEE70] [cid:image007.png@01D81846.CFCAEE70] Thanks [delaware logo]<https://www.delaware.pro/?utm_source=outlook&utm_medium=emailsignature&utm_campaign=signature&utm_content=homepage> +1 916 365 7572 Victor.wood@delawareconsulting.com
  • Level 2
  • Feb 3, 2022 1:12 AM UTC
Hello Victor,
Best Regads,
Mateusz Dudek
Done, Copied response to ticket Thanks [delaware logo]<https://www.delaware.pro/?utm_source=outlook&utm_medium=emailsignature&utm_campaign=signature&utm_content=homepage> +1 916 365 7572 Victor.wood@delawareconsulting.com
  • Feb 15, 2022 11:16 AM UTC
Hello Victor,
Actually, we have the same issue with other table (our case is a Purcharse to Pay table). Can you fix this problem? If yes, how?
Thanks in advance
Fernando
  • Level 2
  • Feb 18, 2022 4:12 AM UTC
Hello Victor,
Thanks in advance
Fernando
Hello Fernando ,
We had a incident open with Helpdesk. They fixed it issue. It works fine in our Sandbox instance. When they deployed the Production instance, it appears they needed to make some changes to the migrated Production instance. Once the changes were made it worked with any issues. It was not clear what those changes were.
You can ask them to reference Case Number: 00104919
Regards
Victor Wood
