number of cases per their throughput time
  • Oct 28, 2021 8:14 AM UTC
  • 73 views
Forum|alt.badge.img+7
hi, I would like to calculate number of cases that have some particular throughput time. I want to divide total number of cases for the cases that happened in less than 4 days and for hose that happened in more than 4 days. I tried to use avg but it calculates for all of the cases and put them all in one column. To be clear: there are cases with status "Closed" that have TT<4, but in the table I have 0 there (in column case count where TT<4)imageimage
status is a column in Case Table
I found a way. Instead of KPI, I used Dimension
COUNT (
  CASE
    WHEN
        CALC_THROUGHPUT (
          ALL_OCCURRENCE [ 'Process Start' ]
          TO
          ALL_OCCURRENCE [ 'Process End' ] ,
          REMAP_TIMESTAMPS ( "_CEL_ISSUE_ACTIVITIES"."_EVENTTIME" , DAYS )
      < 2
    THEN
      "_CEL_ISSUE"."_CASE_KEY"
    ELSE
      NULL
Forum|alt.badge.img+12
Hi @michal.letka11
I guess below PQL query will also work.
CASE WHEN
      CALC_THROUGHPUT(
        FIRST_OCCURRENCE ['Activity 1'] TO LAST_OCCURRENCE ['Activity 2'],
        REMAP_TIMESTAMPS(
      ) < 2 THEN "_CEL_ISSUE_ACTIVITIES"."_CASE_KEY"
      ELSE NULL
You can check this out.
