No Layoutoptions for Pivot-tables?
  • May 24, 2023 11:16 AM UTC
  • 158 views
milan.eric
Level 6
Hello everyone,
I am stumbling accross layout problem right now when working with tables in Celonis. I wanted to make a Pivot-table but I need to update the Layouts to see the full name infront...
Normal tables have this:
While Pivot-tables don´t have any Layoutoptions:
What am I not seeing? This is quite disappointing since I feel like that should be implemented. I need it in this case, since the text is long, and the same until the very end of the text which is not readable.
Same for all the other columns who could be way smaller for my taste.
Any way to fix that or does Celonis not support this?
If there is no way to do it, can I somehow make Celonis aware of this issue? It seems like something minor, but it should be implemented simply due to the fact that normal tables have it.
Thanks!
  • May 24, 2023 12:13 PM UTC
Agree with you... open a ticket with the suggestion
As a idea for a workaround, maybe you could give the first column a long header... maybe that way it will resize so you can see the values in the column...
HTH
milan.eric
Level 6
  • Level 6
  • May 24, 2023 12:51 PM UTC
HTH
Opened a ticket about it thanks! Sadly nothing made it resize. Seems to be quite static...
  • May 26, 2023 5:52 AM UTC
sounds like a product update
