Need to export table data from Transformation Job by running SELECT statement.
  • Mar 31, 2022 2:23 PM UTC
  • 96 views
Hi Team,
I need your help.
I have a table (T1) which has 5000 records. Wanted to extract all the records in CSV from the Transformation Job by the query (SELECT * FROM T1).
Problem :
In transformation job, I can only view 100 records.
Also the table is not in the data model, so I will bot be able to create an OLAP table in the analysis and download the data.
Please advice.
Regards,
JB
Hi @z.b , I would add the table in the Data Model without connecting it to any other table and then extract it as an OLAP table. As far as i know you can't extract a csv from the transformations.
  • Level 5
  • Apr 12, 2022 3:00 PM UTC
Hi @1460067637 ,
Thank You. Had to do the way you have described.
However it would have been great to have such a feature in the transformation as introducing a table in the Data Model and loading it would consume APC .:-(
Regards,
JayB
