Need to build a KPI using three or more columns rules
  • Oct 28, 2021 10:34 AM UTC
  • 6 replies
  • 74 views
Forum|alt.badge.img+7
Hi Team,
I'm trying to build a KPI shows which column data has wrong fields.
I'm using the KPI syntax as below but it is not working. Could you please help me on this case.
CASE WHEN LEN ("TableA_xlsx_TableA"."Name") > 4 OR ("TableA_xlsx_TableA"."Name") IN_LIKE ('!','@','#','$','^','*','(',')','-','_','+','=','{','}','[',']','|','/',':',';','"','<','>',',','.','?','[%]') THEN 'Name, ' ELSE '' END ||
CASE WHEN ("TableA_xlsx_TableA"."Country") IN_LIKE ('!','@','#','$','^','*','(',')','-','_','+','=','{','}','[',']','|','/',':',';','"','<','>',',','.','?','[%]') THEN 'Country, ' ELSE '' END ||
CASE WHEN ("TableA_xlsx_TableA"."SubID") IN_LIKE ('0', '1', '2', '3', '4', '5', '6', '7', '8', '9') THEN 'SubID' ELSE '' END
KPI
Hi Gundappa,
I've tested your code and should work:
image.pngI've only changed the Table names when transforming the file upload.
In the next picture you can see the results
analysisThis analysis shows an OLAP TABLE with a custom KPI with the PQL code you provided and it works!!
Sorry to don´t find a bug,
Javier
Hello Javier,
Thank you for the answer. Could you please help with handling the null values, if there are any null values in any of the column then the code is not working for that row.KPI2
Code is:
CASE WHEN LEN ("NEW_xlsx_Sheet1"."NAME") > 4 OR ("NEW_xlsx_Sheet1"."NAME") IN_LIKE ('!','@','#','$','^','*','(',')','-','_','+','=','{','}','[',']','|','/',':',';','"','<','>',',','.','?','[%]') THEN 'Name, ' ELSE '' END ||
CASE WHEN ("NEW_xlsx_Sheet1"."COUNTRY") IN_LIKE ('!','@','#','$','^','*','(',')','-','_','+','=','{','}','[',']','|','/',':',';','"','<','>',',','.','?','[%]') OR LEN ("NEW_xlsx_Sheet1"."COUNTRY" ) > 4 THEN 'Country, ' ELSE '' END ||
CASE WHEN ("NEW_xlsx_Sheet1"."SUBID") IN_LIKE ('0', '1', '2', '3', '4', '5', '6', '7', '8', '9') THEN 'SubID' ELSE '' END
Output is as below
KPI2Thanks in advance for your help!
Gundappa
Hi Gundappa
I think with an additional check wheter is null the column would make the deal, for instance for the first part of the query I owuld try:
CASE WHEN
(ISNULL("TableA_xlsx_TableA"."Name") = 0)
AND
(LEN ("TableA_xlsx_TableA"."Name") > 4
OR ("TableA_xlsx_TableA"."Name")  IN_LIKE ('!','@','#','$','^','*','(',')','-','_','+','=','{','}','[',']','|','/',':',';','"','<','>',',','.','?','[%]'))
Hope it helps
Javier
Hi Gundappa
CASE WHEN
AND
Hope it helps
Javier
THANKS TON Javier. Now I'm able to handle the null values 😊
👏 Glad to help
Regards
