Need help with extracting data from OLAP table using PyCelonis 2.4.0- AttributeError: 'Analysis' object has no attribute 'get_content'
  • Aug 23, 2023 2:34 PM UTC
  • 108 views
akshay.patil14
Level 2
I'm currently working on extracting data from an OLAP table using the PyCelonis library. However, I've encountered an AttributeError while attempting to retrieve the content of an analysis(olap table). Here's the code snippet I'm using:
```python
celonis = get_celonis()
space = celonis.studio.get_space('4c************1b')
package = space.get_package('64**************de')
analysis = package.get_analysis('e7*************b')
content = analysis.get_content() # This line raises an AttributeError
The error message I'm receiving is:
AttributeError: 'Analysis' object has no attribute 'get_data'
I've checked the documentation, but it seems that the 'Analysis' object doesn't have a 'get_content' attribute. Could you please guide me on how to correctly retrieve the data or content associated with this analysis? What method or function or attribute should I use after the 'analysis' object to access the analysis data?
memrac.c
Level 1
  • Level 1
  • Aug 23, 2023 5:07 PM UTC
I was having the same problem yesterday and what worked for me was:
space = celonis.apps.get_spaces().find('9*******')
package = space.get_packages().find('9*******')
analysis = package.get_analyses().find('********')
content = package.get_analysis(analysis.id).get_content()
sheets = content.draft.document.components
sheet = sheets.find('*********')
components = sheet.components
I got this answer following a snippet of code in here: Pulling Data from an Analysis - PyCelonis
I think it changed in the version 2.4.1 and the way you was doing it is now deprecreated.
akshay.patil14
Level 2
Hey Memrac,
Thank you very much, That works!
