Need help to join 2 SAP S/4HANA tables in a data extraction job with child table key value (16 digits leading zeros) and parent (10, 1 leading zero) are formatted slightly differently
  • Sep 22, 2023 8:29 AM UTC
  • 168 views
Tried using Data type conversion CAST_TO_STRING, syntax seems OK, but get error when executing data job:
Error setting up extraction. Illegal join path configuration. Used resource neither child nor parent [CAST_TO_STRING(DFKKZP] - [DFKKZP] / [DFKKPOH]. Celonis Support ID: 2b8cab5b-7442-41cc-9878-77ef645eeed1
Able to help?
Hi Christian - Do you still need help? If so we can have an expert take a look and help you out.
  • Sep 27, 2023 9:24 AM UTC
yes please, I've tried also contacting, but get syntax error directly in EMS (before even executing it on SAP side): DFKKZP.SELW1 = CONCAT(`000000` , DFKKPOH.PYORD);
