Multiple source system integration with Celonis EMS to show end to end process flow
  • May 1, 2023 8:09 AM UTC
  • 159 views
We have a requirement to connect multiple source systems with the celonis process mining application and then merge event logs from these different source systems to show end-to-end process flow. Also, we wanted to understand how different source systems like Salesforce CRM, SAP ERP, and custom business applications can be combined integrated with celonis process mining application to show the end-to-end interconnected business processes that are flowing through these source systems. Is it possible to combine these event logs from the different source systems within celonis process mining or do we have to connect these different source systems to the datalake system and then perform an event log merge outside of the celonis process mining application.
muthappan.alaga
Level 8
Hi Navalan,
Talk to your customer value manager from Celonis and he can guide you.
Individual processes are Mined using standard connectors, you can merge more than one processes using some custom logic.
Processsphere is another new feature celonis is working can solve to show end to end of multiple processes together.
Thanks
Muthappan
  • May 1, 2023 11:14 AM UTC
Hi Navalan,
Thanks
Muthappan
Hi Muthappan,
Thank you for taking time to answer my question. I have scheduled a call with Ecosystem advisory team and am confused about whether Multi event log or processshpere , which of these celonis capabilities can support these kind of use case
