ML Workbench Examples / GitHub Repositories
  • Sep 22, 2026 7:38 AM UTC
  • 5 replies
  • 180 views
Ayse Nurperi Ozgen
Level 9
Forum|alt.badge.img+14
I’m currently exploring the Celonis Machine Learning Workbench and looking for some practical examples to learn from.
I found the official PyCelonis Examples repository on GitHub, which is very helpful for understanding PyCelonis and interacting with Celonis resources. However, I was wondering whether there are also repositories, sample notebooks, or templates focused more on end-to-end ML Workbench use cases.
I’m particularly interested in Supply Chain examples such as:
  • Late/on-time delivery prediction
  • Supplier or procurement risk prediction
  • Inventory-related predictions
  • Lead time prediction
  • Bottleneck or process outcome prediction
I also came across the older O2C – On-Time Delivery Prediction example, but it seems to rely on the legacy celonis_ml package.
Does anyone know of any up-to-date PyCelonis 2.x / ML Workbench GitHub repositories, Jupyter notebooks, or sample projects that could be used as a starting point?
And if you have built something similar yourself and can share the general approach or architecture, I’d love to learn from it. 😊
Thanks in advance!
This is the approach that I would follow for the same
  1. Define prediction point — only use information available at that point in time.
  2. Feature engineering — supplier performance, lead time, PO changes, quantity, material, plant, etc.
  3. Export data to ML Workbench using PyCelonis
    • PyCelonis Documentation
  4. Train and validate ML model — start with Logistic Regression / Random Forest / XGBoost.
  5. Generate predictions for current/open POs.
  6. Bring predictions back into Celonis as risk scores/predicted outcomes.
  7. Use predictions operationally — dashboards, Action Flows, alerts/interventions.
  8. Measure impact — compare predicted-risk cases, interventions, and actual outcomes.
  9. Supply-chain ML examples to use as modelling references:
    Supply Chain Analytics — Late Delivery / Shipment Duration Prediction
    Supply Chain Late Delivery Prediction
    Late Delivery Prediction — ML/API Example
abhishek.chatu14
Ayse Nurperi Ozgen
Level 9
Thank you so much for the detailed explanation! This is exactly what I was looking for.
Really appreciate you taking the time to share this!
Chitra
Forum|alt.badge.img+2
  • Celonaut
  • Sep 28, 2026 7:40 AM UTC
Thank you ​@abhishek.chatu14 for the detailed answer👏🏻
​@Ayse Nurperi Ozgen
I’m glad to hear that the solution provided in the community helped resolve your issue!
If you have a moment, could you please mark the answer as "Best answer"?
This helps other community members who might encounter the same issue find the right answer more quickly.
Thank you for being a part of our community!
Ayse Nurperi Ozgen
Level 9
Thank you ​@Chitra ! 😊 It was indeed the best answer and helped me resolve my issue. I’ve marked it as “Best answer”. Thanks again, ​@abhishek.chatu14 for your support! 👏🏻
Chitra
  • Celonaut
  • Sep 28, 2026 7:51 AM UTC
Thank you for the quick response ​@Ayse Nurperi Ozgen
Appreciate it 🙂
