ML: How to set PQLFilter to be case insensitive?
  • Apr 3, 2023 12:54 PM UTC
  • 140 views
Hello, I have an ML script-filter:
from pycelonis.pql import pql
query += PQLFilter(query=FILTER TABLE.COLUMN='Test')
and need to set it up to that 'test', 'TEST', 'Test' will return the result, but cannot find a way in the documentation to setup/disable case sensitivity. How can I do this???
Forum|alt.badge.img+14
you can force the table to either, allcaps or all lower case. Like below
query += PQLFilter(query=Filter Lower(table.column) = 'test')
  • Apr 3, 2023 3:27 PM UTC
Great, thank you
