Migrate analysis from CPM > 4.5 to IBC
  • Jul 6, 2021 4:43 PM UTC
  • 131 views
dennis.albre
Level 1
Forum|alt.badge.img+3
Hi everyone,
we have a lot of use cases and dashboards created on our CPM that we updated to 4.6 and we want to migrate our analysis from CPM to the IBC. Before the update from 4.5 to 4.6 we used a python script with pycelonis to transfer the analysis. After the update the script is not working anymore. Is there a specific adjustment to the script or is there any other way to transfer the analysis?
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Jul 26, 2021 1:20 PM UTC
I would get in touch with your EMS (/IBC) Celonis contact, they're quite eager to help you sort this out ;)
Alternatively you could modify your Python script to use pycelonis' replacement: https://python.celonis.cloud/docs/pycelonis/en/latest/reference.html
dennis.albre
Level 1
  • Level 1
  • Jul 26, 2021 1:33 PM UTC
Hi Joos,
thank you for replying.
I'd like to try to modify our Python script. Unfortunately I am not able to access the link you have provided.
Is there a public accessible version of the mentioned page?
joos.buijs
  • Level 10
  • Jul 26, 2021 1:40 PM UTC
My bad, wrong (old) URL :D
This one should work:
https://celonis.github.io/pycelonis/reference.html
