Merge two parallel paths in action flow
  • December 5, 2024
  • 132 views
vamsimadhavg
Level 2
I am trying to query data in Celonis module in the Action flow . However, I have requirement to split the data into two paths and then prepare a csv and then merge it back into one using a text aggregator. Is there a module that can merge paths in action flow. Or is there a way to split data based on filters and merge or append it into one file
