Merge or Combine
  • Mar 10, 2025 1:14 PM UTC
  • 7 replies
  • 453 views
Saba
Level 8
Forum|alt.badge.img+3
Hello Everyone,
In my View, some numbers appear twice — one row contains lead time and price for version A, and the other row contains lead time and price for version B.
So for a specific number, you either see data for version A or version B, but I want to combine them into a single row for that number.
Here’s an example of how my data looks now:
Number Lead Time A Lead Time B Price A Price B
12345 28 - 10.88 -
12345 - 7 - 6.94
And this is what I want to get:
12345 28 7 10.88 6.94
Is there a way to do this?
Thanks a lot!
abhishek.chatu14
What is the pql query you are using for Lead Time A and Lead Time B ?
Saba
Level 8
  • Level 8
  • Mar 11, 2025 7:39 AM UTC
Thank you for your answer.
First Query:
CASE
    WHEN left("o_celonis_MaterialMasterPlant"."ID", 3) = 'P20'
    AND "o_celonis_MaterialMasterPlant"."PlannedDeliveryTimeDays" IS NOT NULL
    AND "o_celonis_MaterialMasterPlant"."PlannedDeliveryTimeDays" != 0
    THEN "o_celonis_MaterialMasterPlant"."PlannedDeliveryTimeDays"
Second Query:
CASE
    WHEN left("o_celonis_MaterialMasterPlant"."ID", 3) = 'P18'
FYI:
MaterialMasterPlant.ID contains a mix of IDs starting with 'P18' and 'P20'. Since I only want to extract the first 3 characters, I used left…
I have created a separate column for P18 and another column for P20.
For better readability, I labeled the columns as Lead Time A and B and Price A and B here as a sample but the correct ones in my view are Lead Time P18/P20 and Price P18/P20.
ilker.karak11
Level 2
You can try to aggregate the KPI with SUM like:
SUM(
CASE
ELSE 0
END)
This should fix the creating an extra column for the null values issue.
Using PU functions with specified filters instead of CASE WHEN statement is another option.
Hope this helps.
Saba
Level 8
  • Level 8
  • Mar 11, 2025 3:20 PM UTC
Thank you for the suggestion!
However, using SUM will give me 0 instead of NULL, which is not what I am trying to achieve.
Some values are split across two rows. In one row, I have Lead Time and Price for P20 but P18 is null, and in the next row, it's the opposite. I want to combine them into a single row so both P18 and P20 values are shown together — not split or null or 0.
Is there a way to achieve this?
Also can you mention your PU function Idea?
Appreciate your input!
ilker.karak11
Level 2
For PU, you can try something like this for each version,
SUM(PU_SUM(DOMAIN_TABLE( "o_celonis_MaterialMasterPlant"."ObjectID"),"o_celonis_MaterialMasterPlant"."PlannedDeliveryTimeDays",YOUR FILTERS FOR VERSION A HERE))
Do you have any additional column in the table about material master plant ?.
This can be the reason of 2 rows of result in CASE WHEN. It’ll be same in PU too if you have any.
Saba
Level 8
  • Level 8
  • Mar 13, 2025 8:41 AM UTC
Price and Lead Time are both from MaterialMasterPlant
abhishek.chatu14
The easier way is you need to first do this in your backend
Create a new table something like this
SELECT
Number,
MAX(LeadTimeA) AS LeadTimeA,
MAX(LeadTimeB) AS LeadTimeB,
MAX(PriceA) AS PriceA,
MAX(PriceB) AS PriceB
FROM
your_table_name
GROUP BY
Number;
Now when you display the results you shold not have a problem
