Match_activities function question - displaying all data when the variable is null
  • Apr 17, 2023 12:08 PM UTC
  • 134 views
Please improve this code,
FILTER MATCH_ACTIVITIES ( "finalResult_0_005"."ACTIVITY" , NODE ['<%=display_code_1%>'] ) = 1;
so that when nothing is assigned to the display_code_1 value, it displays all the data.
I tried
FILTER CASE WHEN '<%=displayCode_1%>' IS NULL THEN 1 ELSE MATCH_ACTIVITIES("Correlation_0_0075_remove_1st"."ACTIVITY", NODE['<%=displayCode_1%>']) END = 1
this code but it did not worked.
It returns MATCH_ACTIVITIES: Could not find activity []. this message.
Thank you
Hello @keonhyuk.song , please let us know if you still need assistance with this question?
  • Jun 13, 2023 2:12 PM UTC
Hello @robert.mcgin , I would like to know if there is a solution to this matter please, since I'm facing the same problem. Thank you in advance!
