Match_activities function question - apply like function on Node
  • Apr 17, 2023 12:09 PM UTC
  • 118 views
Please modify this code,
FILTER MATCH_ACTIVITIES ( "finalResult_0_01"."ACTIVITY" , NODE ['<%=display_code_1%>'] ) = 1;
so that it also works with variables similar to display_code_1.
I tried
FILTER TO_STRING(MATCH_ACTIVITIES ( "finalResult_0_01"."ACTIVITY" , NODE ['<%=display_code_1%>'] )) LIKE '1%';
this code and also some contains, regex_like etc but Celonis EMS does not recoginze both function.
Thank you
Forum|alt.badge.img+3
  • Celonaut
  • May 25, 2023 3:31 PM UTC
Hello Keonhyuk,
MATCH_ACTIVITIES generates a binary result, so wrapping this in TO_STRING will not change your output. Instead of the NODE argument, you should use the NODE_ANY argument which takes a list of possible activities.
Please see the below documentation on MATCH_ACTIVITIES.
https://docs.celonis.com/en/match_activities.html
Thanks,
DS Team
  • Celonaut
  • May 31, 2023 2:15 PM UTC
Dear Keonhyuk,
We hope this email finds you well and you are staying safe.
We are following up since we haven’t heard from you for 5 calendar days, we wanted to put this back on your radar. Have you been able to review my last post? Is there anything you need clarified?
When you have a free moment, we would appreciate your follow-up. If this is already resolved, no further action from your side is required and we will change the case to Closed after another 5 days.
Once a case is moved to Closed, there is still a grace period of 1 calendar day before the final closure. This means that the case will reactivate when a reply is received within this period. Our Customer Support Team is available 24/7 and stand ready to assist you.
Thank you in advance for your time, and I hope to hear from you soon.
Feel free to visit our Community to track your request.
DS Team | Customer Support
