Login screen is power intensive
  • Apr 12, 2022 8:30 AM UTC
  • 85 views
Every time I access Celonis login screen, my PC starts going crazy; CPU and GPU usage up +50%, draining memory and fan spinning like a jet engine. I am pretty sure it is caused by the fireworks animation that adds no value whatsoever.
Once I pass the login screen and land to Celonis main screen, everything goes back to normal. So not a big problem. But it is kind of annoying that it happens every time I try to use Celonis first time in the day. Checked with my colleagues and they have similar experience.
I only experience this kind of problem only for Celonis login screen. All other web sites work fine. Can you stop this animation please? It's not adding any value, in fact, it deteriorates our experience.
Oops, I thought I was posting to Support...It would be good to hear from the others though
Forum|alt.badge.img+27
@naoyuki.tomiz,
Never had this experienced, but I was quite curious on how this was possible. Instead of a moving image such as a GIF, the dots in the login screen are coded in the source code, meaning that this could indeed take some power.
Let's see what the support case will bring you.
Yep it happens to mee too.... probably it is because they coded the animations with js .... image.png
