Link to Studio / Business Views from Transformation Centre
  • Jan 27, 2021 1:42 PM UTC
  • 144 views
neil.whita
Level 4
Hi, Currently, I can see the ability to link an analysis within Process Analytics to the Transformation Centre KPI but was wondering if its possible to instead link to a specific Business View instead? I cant currently see this is possible but I may be missing something simple or is this something that is planned. Look forward to hearing from you
Hi Neil, thanks for raising the question! Indeed, it is not possible yet to link from a KPI in the Transformation Center to an analysis inside Business Views. We put it on our roadmap and plan to release this feature after Celosphere (April 13-15). Well keep you posted! Best, Teodora Join us at the Celosphere http://celon.is/JoinCelosphere
neil.whita
Level 4
  • Level 4
  • Mar 17, 2021 11:16 AM UTC
Thanks for the response Great news, look forward to seeing this update after Celosphere
  • Sep 19, 2022 8:09 AM UTC
Hi Teodora,
Are there any updates planned regarding the Transformation Center? The current documentation refers to the Process Analytics module (link: https://docs.celonis.com/en/transformation-center.html) , which isn't in use anymore as far as I know.
Thank you for your time.
Bob
