layer (background) in Views
  • May 24, 2023 11:52 AM UTC
  • 106 views
Forum|alt.badge.img+14
Hi everyone,
i am trying to create a view, where there is a process in the background and some KPI's in the front (please see screenshot). This lets the user know the value of the KPI at different stages of a process (e.g. # cancellations during order management process of O2C and # cancellations during logistic process of O2C).
But i don't see any way of overlapping with layers (as in powerpoint) OR selecting a background image for a component/section/column in Views.
All ideas are welcomed 😊
thanks
Hi Himanshu,
Thank you for your question. Please be informed that you can change the colors of some of the view components (ex, Chart). And for the text component, you can also use some HTML code. Please see the below documentation.
Hi Mentor,
thanks for your reply.
Unfortunatly that doesn't correspond to my use case. I have tried to show what i want below in the screenshot. In Powerpoint, one has the option of layering different components, so i created an arrow in blue color and the respective 3 text boxes and put the blue arrow in the "background" . This gives the user an understanding on how these values correlate to each other (meaning they are a part of the process).
The color and html options only take effect within the component, they sadly donot give me the possiblity to define the layer of the component (in background or front). As soon as i have a background image, i am not able to put another component (chart, textbox etc.) on top of it in the front.
