I created a Chart and face the problem that the expression of the KPI does not fit into the tooltip.
Option 1: Is there a setting to change the size of the tooltip box?
Option 2: Alternatively I wanted to limit the characters of the variables. Could you help me to insert a LEFT or RIGHT statement? My syntax does not work.
<%= MyVariable %> --> Full text is shown
<%= LEFT(MyVariable,10) %> --> Only show the left 10 characters
Best answer by Anonymous
Hi Marc,
Expanding your post helped to see your full response.
I inserted an image below to better explain my question
Any help is appreciated.
Hi Thorsten,
OK, I didn't catch that it was the KPI title that you wanted to limit 'dynamically'. After a couple of trials, I think I managed to get it how you want:
I already have my variable 'TEST' that holds either 'FIRST_OCCURRENCE' or 'LAST_OCCURRENCE' in my case.
first I create a formula that will hold the requested statement to limit the length. I called my formula 'SHORT' and it reads the first 10 characters of my variable 'TEST': LEFT ('<%=TEST%>', 10). Note that here the variable is set between single quotes. You could also use a variable for the limit (10) if you want to have it changeable, but without quotes.
then I call the formula in a variable of type 'static value' called SHORT_TXT: KPI (SHORT)
in the KPI name, I call variable 'SHORT_TXT'
whenever I change my variable 'TEST' with the dropdown, it changes the title of the KPI accordingly.
for option 1, most KPIs have a set of parameters that can be accessed from the Settings area. For example, in a bar chart, you can define the size of the Dimension Axis:
for option 2, the statement should not be put inside the variable name but outside: LEFT(<%=MyVariable%>, 10)
A
Anonymous
Answer
May 26, 2021 10:40 AM UTC
Hi Marc,
Hi Thorsten,
