Issues with Asset Libray
  • Jan 16, 2024 9:21 AM UTC
  • 8 replies
  • 197 views
Forum|alt.badge.img+7
Hello, I have been facing some issues accessing the Asset Library. I fill in with my credentials but messages like this appear: "You do not have access to the Apex class named 'qsydFileExplorerController'." Can anyone tell me why and how to solve it?
Thanks
Forum|alt.badge.img+28
Hi @chiara.vozze,
Same issue here. The link to the Asset Library is also not visible to me in the header of the Partner Portal, so it seems that something has been restructured in a bad way.
  • Jan 16, 2024 11:01 AM UTC
docs.celonis.com is also not working as before. If this is the new documentation page then it is 10x worse
  • Jan 16, 2024 11:17 AM UTC
well, the documentation problem is fixed. i don't know if anyone else had the same problem tho
andré.tafur
Level 8
Forum|alt.badge.img+19
I'm experiencing similar issues in Celonis Academy, I cannot log or restore my password.
I had the same problem indeed, and it's working again for me too.
  • Jan 17, 2024 12:01 PM UTC
Hi @chiara.vozze,
Hi @janpeter.van.d @chiara.vozze . The menu issues on the partner portal and the Asset Library error have been resolved.
Apologies for the disruption.
  • Jan 17, 2024 12:05 PM UTC
Hi @andré.tafur Celopeers and Academy users are the same. Can you try clicking on Resources>Academy under the Celopeers top menu, please?
andré.tafur
Level 8
Hi Iván,
Thanks for your help, previously I opened a service ticket and the issue was fixed.
