Issues when extracting from CDPOS table.
  • Aug 4, 2023 8:03 AM UTC
  • 96 views
karol.trzci12
Level 4
I'm trying to extract some additional data from CDPOS table using extraction that is separate from our main one. However, it doesn't seem to start to extract. Log shows that job was released to SAP but it won't start actually extracting anything.
Does any one have any ideas what might cause it? Could maybe adding something to FIlters help?
Thanks,
Karol
  • Aug 4, 2023 11:07 AM UTC
I just experienced that filtering on the changenr. is extremely slow in SAP. It is much faster if you look for the objectids. In a similar case, I therefore extract the CDHDR first (there the filter on the changenr is fine, or maybe you are using the date anyways), then create a list of objectids that you can use as column filters and once in Celonis, filter again on the changenrs you are interested in.
BR
Stephanie
