Issue with PQL to adapt KPI to line chart months
  • Sep 8, 2025 7:12 AM UTC
  • 162 views
lisaschneider
Level 1
Forum|alt.badge.img+5
Hi!
I’Ve been struggling with setting up the correct PQL for visualising a KPI on a line chart showing a timeline as the formula became quite complicated. Would appreciate any help on understanding what query I need or why it is not working.
The KPI I want to display on a timeline chart is a cancellation rate. The view contains an input dropdown as a variable  ${outlier_analysis_selection_main.pql} which the dashboard should adjust to. The dimensions of the line chart are ROUND_MONTH("CASE_TABLE"."DSL_ORDER_DT").
In the line chart, I already have the overall cancellation rate.This does not adjust to any user filtering done through the dashboard, nor the selection through ${outlier_analysis_selection_main.pql}. I also have another cancellation rate line which does adjust to any user filtering done. I can therefore compare the development of the cancellation rate for whatever is selected to the overall cancellation rate.
Now I want to add a line that always shows me the cancellation rate of the top 20% performers, based on the selected ${outlier_analysis_selection_main.pql} while making sure only regard cases with more than 100 orders. This line should also not adjust to any user filtering in the dashboard. Below is the PQL formula I have now but which is not working as expected becuase of the CONSTANT(). This obviously disregards the months and gives me the same value for each month. I cannot figure out however how to adjust it to make it work. I cannot pass ROUND_MONTH("CASE_TABLE"."DSL_ORDER_DT") instead of CONSTANT() as this does not work with PU_Quantile. I cannot pass DOMAIN_TABLE (${outlier_analysis_selection_main.pql}) as I then have duplicated domain tables which also gives me an error. Any help is appreciated!
PU_QUANTILE( CONSTANT(),
    PU_count_distinct(DOMAIN_TABLE (${outlier_analysis_selection_main.pql}), "_cel_O2A_activities"."_CASE_KEY"
      , "_cel_O2A_activities"."ACTIVITY" IN (
          'Auftrag storniert',
          'BP Update Failed (COM)',
          'Storniert-technischer Grund',
          'Bonitätsprüfung negativ (BDSG)',
          'Bonitätsprüfung negativ',
          'Auftrag fehlerhaft',
          'Closed-Invalidated',
          'Portierung abgelehnt',
          'Storniert-technischer Grund CC',
          'Bereitstellung abgelehnt'
    ), 0.2,
  PU_COUNT_DISTINCT(
    DOMAIN_TABLE(${outlier_analysis_selection_main.pql}),
  ) > 100
Forum|alt.badge.img+28
Hi ​@lisaschneider,
In this cases, you could try the Timeline Table function: https://docs.celonis.com/en/timeline_column---timeline_table.html, being a bit complex but very powerful function.
It creates partitions over a time scale, which could make CONSTANT() functions work properly.
I hope this guides you in the right direction.
