Issue with Knowledge Model Global Filter & PU-Function
  • Oct 28, 2025 1:00 PM UTC
  • 266 views
Thomas Keim
Hello Community,
I have the following “problem,” or am I misunderstanding something here?
SAP Example
I have an Sales Order (Table VBAK) with 6 items (Table VBAP). On Item has the Category “TAX” (Field VBAP.PSTYV)
Within the Knowledge Model I have set an global filter FILTER VBAP.PSTYV NOT IN (‘TAX’)
This works as expected and I only see only 5 items when I display the data in flat table or using the count function e.g. COUNT(VBAP.POSNR)
But when I use the PU_COUNT Function PU_COUNT(VBAK, VBAP.POSNR) I get 6 items as result.
My question here: Is this expected behaviour and does PU_FUNCTION ignore global knowledge model filters? Or is this a bug?
Best, Thomas
fabian.wende
Level 6
Hello Thomas,
PU-Functions indeed ignore filtering in this way, as stated here:
Pull Up Aggregation
In contrast to that the Pull-Up-functions ignore the global filter state and are calculated only once.
To achieve, what you want to do, you need to include the same filter in the filter-statement of the PU_COUNT-Funtion:
PU_COUNT(VBAK, VBAP.POSNR, VBAP.PSTYV NOT IN (‘TAX’) )
Fabian
Forum|alt.badge.img+28
Hello Thomas,
Pull Up Aggregation
Fabian
Or use the FILTER_TO_NULL statement to apply current Filters to the PU-outcomes: https://docs.celonis.com/en/filter_to_null.html. This is quite memory consuming, so might slow down your calculations at certain points.
