Issue with csv file uploader
  • Nov 17, 2023 8:31 AM UTC
  • 93 views
HI ,
I am facing the issue with file uploading , when I have upload the csv file after that in map the data section there is no content visible for me .
attaching the snap for the same.error1
Hi I would suggest creating a Support ticket by attaching the actual CSV file you observed the issue.
