Issue on calculation with Pull-Up Function
  • Jul 8, 2022 10:34 AM UTC
  • 212 views
I created a PULL UP function as mentioned below
PU_SUM(DOMAIN_TABLE ( "PR_CASES"."CUSTOMER_NO" || "PR_CASES"."CUSTOMER_NAME")  ,  CASE WHEN "PR_CASES"."CREATED_BY" = 'WF_PDP011' THEN 1 ELSE 0 END)
This is to get the Total Automatic Ticket Creation per Customer. However, on trying to filter the column based on date picker field ("PR_CASES"."CREATED_AT"). It was observed that the PULL up function is not getting impacted and the value remains the same.
Kindly suggest how to resolve this.
Thank you in advance :)
  • Jul 13, 2022 1:39 AM UTC
Dear @shravya.b11
As documented at Pull Up Aggregation (celonis.com), the Pull-Up-functions ignore the global filter state and are calculated only once.
If you just get the sum of "CASE WHEN ..." customer, you just use Customer as dimension and SUM aggregation as KPI in OLAP table instead of PU_SUM. Then you can filter PR_CASE by date picker as expected.
Kazuhiko
  • Level 6
  • Jul 13, 2022 11:29 AM UTC
Hi @kazuhiko.takat12
Thank you so much for your valuable inputs. We tried with simple SUM and it is giving correct results. But, our requirement was to create a KPI based on the above formula. So, we were specifically using pull up functions based on customer data.
We just found a solution from other sources : FILTER_TO_NULL which can be used specifically to avoid the standard behavior of aggregation functions. So, this worked for us.
Thank you :)
  • Jul 13, 2022 11:36 PM UTC
Dear @shravya.b11
It is nice to hear that you can find your solution. FILTER_TO_NULL is new for me, so I am also helpful.
