Is there any workaround to assign a default value for package runtime variables?
  • Nov 15, 2023 2:32 PM UTC
  • 72 views
  • Nov 15, 2023 2:49 PM UTC
Could you elaborate a bit more on what your goal is here?
If you are looking for assigning a default value to a package run time variable, then you can simply enter it's value in the plain text box. See below:plain text value, package run time variable
You can find more here: https://docs.celonis.com/en/package-runtime-variables
