Is there any way to open SAP system from Celonis?
  • Jul 29, 2022 2:28 AM UTC
  • 89 views
In my project we are looking to open SAP system directly from the Celonis Analysis. E.g. if I select an PO from Analysis, and click on Button to Open SAP system. Button should redirect to SAP system with the the table from where ussr can take action on that particular PO.
Forum|alt.badge.img+3
  • Level 0
  • Sep 6, 2022 9:21 PM UTC
This is possible if you use SAP Net Weaver Business Client or similar which allows you to access your SAP system through the web browser. The Data Service Link feature in the settings of the OLAP then allows you to open the link that forwards you to the corresponding transaction in your SAP client. You can insert values from the OLAP columns using the normal variable syntax: <%=col1%>, <%=col2%>, …
A simple example to search for a document number in Google:
9efba8b3-e88a-4bab-89c5-c9c3251491789c80c654-e23c-4776-a9b4-5341ef4ecfbd
