Is there any way to loop over a table in a SQL transformation?
  • Jul 19, 2024 8:39 AM UTC
  • 160 views
Let's say I have two tables:
 - TABLE A: User ID, many other cols. [PK is User ID]
 - TABLE B: User ID, many other cols. [Many lines per User ID]
Is there any way I can go through each User ID in TABLE A and do in the SQL transformation something such as:
Declare TABLE C
for each User ID in TABLE A
  • Append TABLE A.User ID, TABLE A.Name in TABLE C
  • Select * from TABLE B where TABLE B.User Id = TABLE A.User Id
  • Append TABLE B.User ID, TABLE B.Other Field in TABLE C
The idea would be to create a table in which you can find each line in TABLE A followed by every line for that same ID in TABLE B.
Sorry for the poor SQL terminology, as I am not very used to it.
Thank you so much in advance.
rita.kiss12
Level 7
Forum|alt.badge.img+3
  • Level 7
  • Jul 23, 2024 12:22 PM UTC
Hi Mikel,
If I understood your problem correctly, Table C is a new table that you want to create from a combination of columns from Table A and Table B.
So I don't think you really mean Append when you "declare" table C. (Append means vertically sticking 2 tables together, first each row from one table then each row from the second one, taking the column structure into account.)
I think what you mean, is merge.
And that can be achieved by a LEFT JOIN.
Something like:
CREATE TABLE TABLE_C AS (
   SELECT
         TABLE_A.ID
       , TABLE_A.NAME
       , TABLE_B.*
   FROM
       TABLE_A LEFT JOIN
       TABLE_B ON
       TABLE_A.ID = TABLE_B.ID
TABLE_B.* means every column from TABLE_B but of course you can also just list all the columns you actually need.
 This take ID and NAME columns from TABLE_A and adds all corresponding information from TABLE_B (when available).
  • Jul 23, 2024 12:31 PM UTC
Good afternoon,
No, what I am actually looking for is a way to append many selects. I need to combine two tables by appending line 1 in table A with lines 1 to 6 in table B, line 2 in table A with lines 7 to 10 in table B... the way to choose the number of lines in table B depends on the User ID. That is why I was thinking on doing it by going through the lines in table A and append each iteration the line in table A with the lines in table B.
Thank you,
rita.kiss12
Level 7
  • Level 7
  • Jul 23, 2024 12:45 PM UTC
Append would still only work for the same columns in Table A and B.
If this is your table A:
imageAnd this is your table B:
imageThe code I suggested would give you the following table C:
imageIf this is not the outcome you are looking for, please provide some example data for better understanding the problem.
