Is there a way to show the transformation center chart within an analysis or a Studio View?
  • Mar 21, 2022 5:09 PM UTC
  • 161 views
connor.manth
Level 4
I would like to keep a KPI analysis and transformation center chart on the same page. Is it possible to have some sort of iFrame, or view to transformation center in the Analyses? Or perhaps a Studio View?
Best answer by Rrezarta Musmurati
Hi Connor, unfortunately, Viewing data from the transformation center in an Analysis is not possible. Many thanks for your understanding on this matter. Best regards, Rrezarta
Hi Connor, Thank you for reaching out! For more information please check out : https://help.celonis.cloud/help/display/CIBC/Tracking+Charts+and+Tables+in+Transformation+Center Best regards, Rrezarta
connor.manth
Level 4
  • Level 4
  • Mar 30, 2022 12:45 PM UTC
Thanks, Rrezarta. I guess I should make my question more clear.
I'd like to keep the tracking of a KPI within the analyses. I have a large number of users who get confused about where to find the Transformation Center KPI Historical data. If I have transformation data in the analysis, I think that would minimize their confusion.
Is there a way to view the historical KPI data from the Transformation Center in the analyses?
