Is there a way to select the scale to be picked in a chart in views?
  • Feb 6, 2023 6:57 AM UTC
  • 182 views
pavan.bhara13
Level 4
imageso here if the count is just one then i just need to display 1 in the legend/axis. it should not show 200m, 300m.... etc. is there a way to achieve it?
  • Feb 6, 2023 1:18 PM UTC
Not sure what you are asking, but just in case, you can select the Primary Value Axis and then RANGE as Manual Range.
then set the min and max
and you can tweak the ticks count disabling Auto-Tick count
HTH
abhishek.chatu14
Assuming this is a view you can use the domain property in charts to obtain the same
The domain property in encoding allows you to specify a custom range of values for the encoding field. By default, the domain is automatically calculated from the values in the encoded data field. However, it can be overridden by another visual level encoding, so it's recommended to set the domain property in the top-level encoding. For example, for a quantitative y-position encoding, you can specify a domain of [0, 1] to ensure that the y-axis always spans from 0 to 100%. For a categorical x-position encoding, you can specify a fixed list of values to be shown on the axis.
Find more information here
https://docs.celonis.com/en/chart.html
PS: You can search for domain in the documentation link provided
