Is there a Variant Explorer or Case Explorer in Views?
  • Feb 22, 2023 10:23 PM UTC
  • 80 views
Looking to add a variant explorer in the Views based on my knowledge model.
Similarly - is it possible to have a case explorer?
I believe I can create an analysis linked to the Knowledge model, but then I don't seem to have the ability to select the case table I want to use in the explorers...
abhishek.chatu14
Currently there is no option for a Variant Explorer or Case Explorer in Views.
You can maybe use a button in you Views that links to an Analysis with Variant Explorer or Case Explorer, unfortunate you will not be able to use the filters from an Analysis to View or vice versa for the same
The closest feature to a Case Explore in Views would be Activity History, which may again not server the purpose you are looking for
https://docs.celonis.com/en/activity-history.html
