Is there a technical way to export backups of processes/data model in Celonis so that we can restore them when necessary?
  • Jun 6, 2024 1:24 PM UTC
  • 235 views
  • Jun 10, 2024 9:29 AM UTC
Hi Sevde Aydin,
You can use python in your machine learning workbench and use pycelonis module for accessing the data in a data model and save them as files in the machine learning workbench itself.
Thanks,
Akshay
  • Jun 25, 2024 7:34 PM UTC
Hello Akshay Haridas,
Thank you very much for your support. I set up PyCelonis client library in Machine Learning Workbench and established the connection to our Celonis EMS API. However, I got an error when connecting to the EMS.
I wrote the following commands and I am sure that I used the correct for the environment variables
CELONIS_URL, CELONIS_API_TOKEN and CELONIS_KEY_TYPE but still didn't work.
url = "https://<mycompany'steam>.<realm>.celonis.cloud/"
api_token = "<the-api-token(Application-Key)-for MLWorkbench-from-Admin & Settings -> Applications>"
key_type = "APP_KEY"
celonis = get_celonis(base_url=url, api_token=api_token, key_type=key_type)
And I got the following error:
HTTPStatusError Traceback (most recent call last)
File ~/.local/lib/python3.8/site-packages/pycelonis_core/client/response_processor.py:49, in ResponseProcessor._verify_response(self, response)
48 try:
---> 49 response.raise_for_status()
50 except HTTPStatusError as error:
File ~/.local/lib/python3.8/site-packages/httpx/_models.py:749, in Response.raise_for_status(self)
748 message = message.format(self, error_type=error_type)
--> 749 raise HTTPStatusError(message, request=request, response=self)
HTTPStatusError: Server error '500 Internal Server Error' for url 'https://borusan.eu-2.celonis.cloud/api/cloud'
For more information check: https://httpstatuses.com/500
During handling of the above exception, another exception occurred:
PyCelonisHTTPStatusError Traceback (most recent call last)
Input In [23], in <cell line: 2>()
1 from pycelonis import get_celonis
----> 2 celonis = get_celonis(base_url=url, api_token=api_token, key_type=key_type)
File ~/.local/lib/python3.8/site-packages/pycelonis/__init__.py:135, in get_celonis(base_url, api_token, key_type, user_agent, proxies, connect, permissions, check_if_outdated, retries, delay, verify_ssl, **kwargs)
122 client = _infer_client(
123 base_url,
124 api_token,
131 **kwargs,
132 )
134 if connect:
--> 135 _connect(client)
137 celonis = Celonis(client)
139 if permissions:
File ~/.local/lib/python3.8/site-packages/pycelonis/__init__.py:292, in _connect(client)
290 def _connect(client: Client) -> None:
291 try:
--> 292 TeamService.get_api_cloud(client)
293 logger.info("Initial connect successful! PyCelonis Version: %s", __version__)
294 except PyCelonisPermissionError:
File ~/.local/lib/python3.8/site-packages/pycelonis/service/team/service.py:160, in TeamService.get_api_cloud(client)
149 @staticmethod
150 def get_api_cloud(client: Client) -> UserTransport:
151 logger.debug(
152 f"Request: 'GET' -> '/api/cloud'",
153 extra={
157 },
158 )
--> 160 return client.request(
161 method="GET",
162 url=f"/api/cloud",
163 parse_json=True,
164 type_=UserTransport,
165 )
File ~/.local/lib/python3.8/site-packages/pycelonis_core/client/client.py:154, in Client.request(self, method, url, content, data, files, json, params, headers, cookies, timeout, follow_redirects, type_, parse_json, request_body)
140 request = self.client.build_request(
141 method=method,
142 url=url,
150 timeout=timeout,
151 )
153 response = self.client.send(request, follow_redirects=follow_redirects)
--> 154 return self._response_processor.process(response=response, type_=type_, parse_json=parse_json)
File ~/.local/lib/python3.8/site-packages/pycelonis_core/client/response_processor.py:32, in ResponseProcessor.process(self, response, type_, parse_json)
25 def process(
26 self,
27 response: Response,
28 type_: typing.Optional[typing.Type[T]] = None,
29 parse_json: bool = True,
30 ) -> typing.Any:
31 """Verifies whether response is valid and parses response body if parse_json=True."""
---> 32 self._verify_response(response)
34 if parse_json:
35 return self._parse_response(response, type_)
File ~/.local/lib/python3.8/site-packages/pycelonis_core/client/response_processor.py:51, in ResponseProcessor._verify_response(self, response)
---> 51 self._process_error(error)
File ~/.local/lib/python3.8/site-packages/pycelonis_core/client/response_processor.py:76, in ResponseProcessor._process_error(self, error)
68 def _process_error(self, error: HTTPStatusError) -> None:
69 message = f"""
70 Request : {error.request.method} -> {error.request.url}
71 Headers : {error.request.headers}
74 Data : {error.response.text}
75 """
---> 76 raise PyCelonisHTTPStatusError(message)
PyCelonisHTTPStatusError:
Request : GET -> https://borusan.eu-2.celonis.cloud/api/cloud
Headers : Headers({'host': 'borusan.eu-2.celonis.cloud', 'accept': '*/*', 'accept-encoding': 'gzip, deflate, br', 'connection': 'keep-alive', 'user-agent': 'pycelonis/2.9.0', 'authorization': '[secure]'})
Data :
Response: Server error '500 Internal Server Error' for url 'https://borusan.eu-2.celonis.cloud/api/cloud'
Data : Something went wrong while handling the request. Please contact Celonis customer support. Celonis Support ID: 3aa46e52-dec3-4174-9110-519bf3140c2c
How can I fix this problem? Thank you very much in advance.
