Is the process explorer customizable in such way that in addition to the number of activities per process step, the automation rate of each step will also be shown. Is this possible or has anyone tried to implement such a requirement?
  • Dec 12, 2023 11:51 AM UTC
  • 198 views
julia.bauer
Level 9
Best answer by Anonymous
I know this is possible.
You can create one here:
imageand you can follow the documentation to do so here: https://docs.celonis.com/en/process-explorer-kpis
  • Answer
  • Dec 12, 2023 12:15 PM UTC
julia.bauer
Level 9
  • Level 9
  • Dec 12, 2023 2:15 PM UTC
Hello Noel,
thank you!
I did not find the analysis settings before.
Now it works.
BR
Julia Bauer
