Is the invert selection not possible anymore when fixed buckets are implemented?
  • Nov 13, 2023 12:23 PM UTC
  • 98 views
felix.keite12
Level 2
Hello celopeers. We are using a bar chart graph to display the distribution of cycle times. Cases with a specific cycle time are classified into the corresponding bucket. The feature was used a lot by our business users - however, inverse selection is no longer applicable. Do you maybe know why it is not working?
emiel.van.n14
Level 4
Forum|alt.badge.img+14
Hi Felix,
I just verified this on my end. Did a check for a couple of our clients. Still able to invert selections. Both from the side-menu as well as using the top selection-bar. I know this doesn't help. Have you checked or try to rule-out browser issues? I'm using Safari and Chrome. Both are OK.
emiel.van.n14
Level 4
This question kept me busy. Could it be that you're using a histogram instead of a Bar Chart?
felix.keite12
Level 2
We are using a histogram component
