IS NULL
  • Nov 25, 2025 2:44 PM UTC
  • 96 views
Saba
Level 8
Forum|alt.badge.img+3
This is my code called Cost. I added a filter to show only entries where the cost is null, but it still shows entries with values.
SUM(PU_SUM(o_CELONIS_SALESORDERITEM, "o_custom_CostPerLine"."CostTransactionCurrency",
"o_custom_CostPerLine"."CostElement" IN ('00004', '40020', '400100',  '40220'))
/"o_celonis_SalesOrderItem"."OrderedQuantity"
*"o_custom_CustomerFinanceDocumentItem"."Quantity"
+COALESCE(PU_SUM(o_CELONIS_SALESORDERITEM, "o_custom_CostPerLine"."CostperQuantityTransactionCurrency",
"o_custom_CostPerLine"."CostElement" IN ('46100'))/"o_celonis_SalesOrderItem"."OrderedQuantity"*
"o_custom_CustomerFinanceDocumentItem"."Quantity",0))
my Filter :
Filter (exactly the cost code) is null
Thank you for your help
