Is it possible to use the Conformance Checker on only a certain part of a process?
  • Oct 18, 2023 9:26 AM UTC
  • 100 views
  • Oct 18, 2023 3:00 PM UTC
Hi Elizabeth,
It is possible to use the Conformance Checker on only a certain part. You could for instance enable the following filter:
It will filter for the Subprocess that starts with the specified activity A and ends with a defined activity B. FILTER PU_FIRST ( Case Table, Activity Table.Column Activity Name ) = Activity A AND PU_LAST ( Case Table, Activity Table.Column Activity Name ) = Activity B
Hope this helps!
