Is it possible to use SQL Procedure in data transformations? If not, is it on the roadmap? Thanks!
  • Aug 6, 2021 8:02 AM UTC
  • 66 views
Forum|alt.badge.img+27
Hi Zeynep,
In the data transformations Vertica SQL is used. While Vertica has procedure functionalities, the current configuration in Celonis (so called 'EON Mode') to scale nodes and resources doesn't support this. You can try to request this functionality by creating a ticket on this website, but since this would implies changes in the Vertica functionalities, I don't think it will be picked up.
vertica_ss1
Hi Zeynep,
vertica_ss1
Thank you so much for the detailed explanation! :) @janpeter.van.d
